Configure Locations
Define the location rules to support changes in geographic location and let the agents connect to appropriate scalability servers. The agents evaluate the rules that you create to determine which scalability server to connect.
The Setting Properties dialog opens.
The feature adds a row with the following parameters to the current table structure:
The locations parameter settings are configured.
Important! The feature does not fully verify Address Range or validate the Server Name, Subnet Scan, and Script values. Be careful when you set these parameters.
