The DSM Explorer › Control Panel › Configuration Folder › Configuration Policy › Default Computer Policy (or User-Defined Policy) Node › Agent Policy Group › Common Agent Policy Group › Common Policy Group (Common Agent) › How to Enable and Configure Location Awareness
(Optional) Configure Limit Subnet Scan
You can configure the Limit Subnet Scan to allow or prevent scanning the subnet to find scalability servers in other domains.
- Navigate to the location awareness configuration policy.
The location awareness parameters are displayed in the right pane.
- Double-click Limit Subnet Scan.
- Click Setting Properties in the Tasks portlet.
The Setting Properties dialog opens.
- Modify the Value field as appropriate for your environment.
Default: True
- Click OK.
The Limit Subnet Scan parameter is configured.
