The Security Profile Linkages dialog lets you link or unlink the security profiles with the selected security areas.
This dialog contains the following fields:
Displays the name of the selected security area. If you have selected multiple areas, this field displays the number of areas selected, for example, Multiple Areas (4).
Lists the security profiles suitable for security area support. Select the check box before any profile to enable the security area support. The Linkages column can have the following values based on the linkage status of the selected areas in relation to each security profile:
Indicates that the security profile is linked to all the selected security areas.
Indicates that the security profile is not linked to any of the selected areas.
Indicates that the profiles have a mixed linkage status that is, profiles are linked to at least one and unlinked from at least one security area. This status is possible only when you select multiple areas.
Note: An asterisk (*) before the linkage status indicates the status change after the dialog is displayed.
Links the selected security profiles to the selected areas. This button is enabled if the linkage status of at least one of the selected security profiles is Unlinked or Different.
Unlinks the selected security profiles from the selected areas. This button is enabled if the linkage status of at least one of the selected security profiles is Linked or Different.
Resets the linkage status to the previously saved value. This button is enabled if the linkage status of at least one of the selected security areas is changed after the dialog is displayed. A changed linkage status has a leading asterisk (*).
