The Security Areas dialog lets you turn on or off the security area support globally on the domain manager. Using this dialog, you can create, modify, and delete areas, link security profiles to selected security areas, and take ownership of the selected areas.
This dialog contains the following fields and buttons:
Indicates whether security area support is turned on or off on the domain manager. You can create and link security areas without turning on this option; however, the changes will take effect in your security system only if you turn on this option.
Note: By default, security area support is turned off in the domain managers.
Lists the security areas in the domain manager. The check boxes next to the security area names define the default security areas. The selected security areas are automatically linked to the objects created by the system. You can clear the check box against a security area if you do not want it to be linked to the system objects. The system objects are hidden from the users who are linked to the unchecked areas only.
Note: By turning on and off the security area support and changing the default security areas, you are changing the global settings that affect the security system as a whole.
Opens the New Security Area dialog that lets you create a new security area.
Displays the Confirm Delete message. Clicking Yes, deletes the selected security areas and automatically unlinks from the related security profiles and objects.
Opens the Security Area Properties dialog that lets you modify the name and description of the selected area. This button is enabled when you select only one area.
Assigns the ownership of the selected security areas to the currently logged-in user.
Important! This action is irreversible even if you cancel the dialog.
Opens the Security Profile Linkages dialog that lets you link or unlink the security profiles with the selected security areas.
