The DSM Explorer › Control Panel › Configuration Folder › Configuration Policy › Configuration Policy Node (Control Panel) › Unseal a Policy
Unseal a Policy
You must unseal a policy before you can modify its configuration settings. A sealed policy is marked by a padlock icon:
To unseal a policy
- Right-click a sealed policy in the tree view or in the Configuration Policy pane.
A context menu opens.
- Select Un-Seal from the context menu, or click Unseal in the Tasks portlet of the Configuration Policy pane.
The policy is unsealed and marked with a computer icon with a section reference mark.
More information:
Sealed and Unsealed Policies
