For user-defined policies only, you can remove the current value from a setting at any time and reset it to the default value.
To reset a value to the default value
Alternatively, right-click the setting and select Use Default Value from the context menu.
The value of the setting is reset to its original default value.
Note: This applies only to user-defined policy values, not to the default policy.
