Previous Topic: Parameter ValueNext Topic: Text Parameter
Parameter Description
The lower part of the Edit OS Installation Parameter window contains a short parameter description as it was specified during the associated operating system images build. Depending on the type of parameter, the description contains the following information:
Type
Specifies the parameter type
Maximum Length
Specifies the maximum character length of the parameter value
Minimum Length
Specifies the minimum character length of the parameter value
Maximum Value
Specifies the upper limit for a feasible parameter value
Minimum Value
Specifies the lower limit for a feasible parameter value
Default Value
Specifies the default value assigned for the selected parameter
Comment
Specifies a comment on the parameter specified during the build of the associated operating system image
Parameter Types
