Previous Topic: Password ParameterNext Topic: Mapping List / Mapping List Extended Parameter
Text List / Extended Text List Parameter
TextListExt specifies a list of item=<string>; that is, it is the same as a TextList parameter, but the list can be extended with the parameter editor later on.
The following parameter attributes are valid for this parameter type:
Attribute
Meaning
Range
MaxLength
Maximum length of a list entry
1 to 255 characters
Comment
Comment on the parameter
any string
Trans
Drives the inheritance of parameter settings
{yes|no}
UpdateDefault
Overwrites the default value when updating the image
{yes|no}
Item
Specifies a list item. This attribute can occur more than once.
any string
