Previous Topic: Text ParameterNext Topic: Password Parameter
Numeric Parameter
Specifies a numeric value. The range of the value is given by the attributes MaxValue, which specifies the maximum, and MinValue, which specifies the minimum. The value of MinValue must be less than or equal to the value of MaxValue. The following parameter attributes are valid for this parameter type:
Attribute
Meaning
Range
MaxValue
Maximum of the value assigned
-2147483648 to 2147483647
MinValue
Minimum of the value assigned
-2147483648 to 2147483647 and MinValue <= MaxValue
Comment
Comment on the parameter
any string
Trans
Drives the inheritance of parameter settings
{yes|no}
UpdateDefault
Overwrites the default value when updating the image
{yes|no}
