Previous Topic: Text List / Extended Text List ParameterNext Topic: Boot Image Parameter
Mapping List / Mapping List Extended Parameter
Specifies a list of item=<string1> <string2>. String2 is shown in the editor only, when string1 has been assigned a value.
The parameter editor can extend parameters of type MapListExt, but not of type MapList.
When assigning a value to a parameter, it can only be a string that is appearing in the list.
The following parameter attributes are valid for these parameter types:
Attribute
Meaning
Range
MaxLength
Maximum length of a list entry
1 to 255 characters
Comment
Comment on the parameter
any string
Trans
Drives the inheritance of parameter settings
{yes|no}
UpdateDefault
Overwrites the default value when updating the image
{yes|no}
Item
Specifies a list item. This attribute can occur more than once.
"string1" "string2"
