If you are using Open Workbench with CA Clarity PPM, you can open CA Clarity PPM projects from:
Note: If you are using Netscape Navigator, the browser must be aware of the CA Clarity PPM Schedule Connect MIME type before you can open the project in Open Workbench.
Before opening CA Clarity PPM projects in Open Workbench:
If Open Workbench is running and Schedule Connect is already connected to a CA Clarity PPM server, Schedule Connect attempts to open a project with the same ID from the CA Clarity PPM server to which Schedule Connect is currently connected. If the project ID is not found, the project cannot open.
When you open a CA Clarity PPM project in Open Workbench:
All baseline data is loaded. To only load the current baseline, you must configure the project management settings in CA Clarity PPM and Open Workbench. You can open programs in Open Workbench using CA Clarity PPM in read-only mode.
Note: See the Project Management User Guide for more information.
| Copyright © 2010 CA. All rights reserved. | Email CA Technologies about this topic |
