If you are using Open Workbench with CA Clarity PPM, you can open any project (active or inactive) that you have rights to view or edit in Open Workbench using CA Clarity PPM. To open projects from CA Clarity PPM, they must be formatted for Open Workbench.
If you can view or edit a project, you can choose to open the project in read-only or read/write mode. If you only can view a project or if the project is currently locked, you can open the project as read-only.
When you open a project from CA Clarity PPM, the following occurs:
Note: See the Project Management User Guide for more information.
| Copyright © 2010 CA. All rights reserved. | Email CA Technologies about this topic |
