If you are using Open Workbench with CA Clarity PPM, you can open any CA Clarity PPM project you have rights to view or edit from Open Workbench using CA Clarity PPM Schedule Connect. Use the Open dialog box to open your project from Open Workbench.
When you view the list of projects in the Open dialog box, the following icons display next to the project ID:
You have Project - Edit Management access rights to the project.
Note: This icon displays if the project is a master project.
You have read-only access to the project.
You currently have the project open and locked.
The project is currently locked by another user.
Note: See the Project Management User Guide for more information.
To open a CA Clarity PPM project using Open Workbench
The Open dialog box opens and a list of available projects is displayed.
Displays the CA Clarity PPM server that Open Workbench is currently connected to when opening projects from CA Clarity PPM.
Click to see a list of available project names.
(Default view) Click to see a detailed list of available projects.
Click to open Open Workbench .rmp project files or XML files from your computer or network.
Displays the currently selected folder when opening Open Workbench .rmp project files or XML files from your computer or network.
Click to open projects from CA Clarity PPM.
You can filter the list by using the wildcard (*).
Displays the unique identifier of the selected project.
Defines the type of file you want to open.
Values:
Specifies whether you want to open the project in read-only mode.
Default: Cleared
Note: This check box is only available if you have edit rights to the selected project. If you have view rights to the project, this check box is selected and unavailable.
Specifies whether you want to open the selected project as a subproject in a new master project.
Default: Cleared
Note: You can save this new master project back to CA Clarity PPM.
The project opens in Open Workbench.
| Copyright © 2010 CA. All rights reserved. | Email CA Technologies about this topic |
