Set Up Connection to CA Clarity PPM from Open Workbench
If you are using CA Clarity PPM with Open Workbench, you must manually log in to CA Clarity PPM. When you start Open Workbench, the Log on to CA Clarity PPM dialog box opens. If you installed CA Clarity PPM Schedule Connect from a CA Clarity PPM server, the host name, SSL, and user name default to the host name and CA Clarity PPM user name from which you installed CA Clarity PPM Schedule Connect. You can change these settings. Once you set up the connection and log in, CA Clarity PPM Schedule Connect remembers your settings. If you log on successfully, the existing CA Clarity PPM session is retained from one CA Clarity PPM-dependent feature to another until the CA Clarity PPM session expires. If you request a CA Clarity PPM-dependent Open Workbench feature after the session has expired, you must log on again.
Note: Sessions are not persisted from one system to another except when opening a project from CA Clarity PPM.
When you open a project from CA Clarity PPM to update it in Open Workbench, you implicitly log in to CA Clarity PPM. No additional setup is required if you open a project from CA Clarity PPM. Open Workbench defaults to offline mode when you cancel the log on operation or after you make three failed attempts to log on.
To connect to CA Clarity PPM from Open Workbench
  1. Start Open Workbench.
    The Log on to CA Clarity PPM dialog box appears.
  2. Click Setup>>.
    Additional fields are exposed for you to set up the connection.
  3. Complete the following:
    Note: Contact your administrator or see the CA Clarity PPM Administration Guide for more information.
    SSL Handling
    Determines the secure sockets layer (SSL) handling preference.
    Default: None
    Values:
    • Full. SSL is used for all communications including logins and data exchanges.
    • Login. SSL is used when logging in and is bypassed for all other data exchanges.
    • None. No connection is used through SSL.
    CA Clarity PPM Host
    The name of the CA Clarity PPM server from which you will open a project or to which you will save a project. The server name is not the full URL.
    Example: corpHost.
    Port (CA Clarity PPM Host)
    The port for the CA Clarity PPM server.
    For example, 80 is typically the port for a CA Clarity PPM Server.
    Login SSL Host
    Defines the name of the login SSL host.
    Port (Login SSL Host)
    Defines the port for the login SSL host.
    Proxy Host
    The name of your proxy server. Required only when accessing an authenticating proxy. The proxy server name is not the full URL.
    For example, enter corpProxy.
    Note: If you are accessing CA Clarity PPM through a non-authenticating proxy, enter the proxy host and port in the CA Clarity PPM Host and Port fields.
    Port (Proxy Host)
    The port for the proxy server.
    Proxy User Name
    The user name for connecting to the proxy server.
    Proxy Password
    The password for connecting to the proxy server.
  4. Click OK.
    The connection to the CA Clarity PPM server is established.
More information:
Set the Log on to Server Option
Set Microsoft Internet Explorer Web Browser Options
