Open CA Clarity PPM Projects from a Command Line
You can open CA Clarity PPM projects using the command line. Use this method to open single and master projects without first starting Open Workbench. You can do this from the:
Use the following command line arguments to create or open CA Clarity PPM projects:
The npWBench file.rmp /R CLARITY\[projectID] command opens one or more CA Clarity PPM projects. The project's subprojects are not opened.
projectID
Defines the name of the CA Clarity PPM project you want to open.
To open projects using a command line
  1. Do one of the following:
  2. Enter the command line syntax and press the Enter key on your keyboard.
