Install and Configure CA Automation Suite for Clouds Powered by Amazon Web Services › Upgrade CA Automation Suite for Clouds with the Service cartridge › Verify Upgrade
Verify Upgrade
Verify the upgrade by performing the following steps:
- Log in to CA Service Catalog.
- Click Service Builder, Configuration, and click Content Packs.
The content packs for Release 1.6 and Release 1.5.SP01 appears.
- Verify that all users are available and you are able to log in to CA Service Catalog.
- Compare the values in the contentpack.properties file that is located in the CA ASC Amazon Web Services service cartridge folder with what appears on the screen:
- Content Pack Details
Lists the details that you specified when you created the content pack. For example, the name, version, status, and actions.
- Content Section
Specifies the objects according to the import criteria selected. The following list describes the objects:
- Services
- Service Option Groups
- Forms
- Rule Actions
- Report Data Objects
- Report Variables
You have verified the upgrade.
