This chapter contains troubleshooting topics that are related to CA Automation Suite for Clouds powered by Amazon Web Services.
To open a support issue or enhancement request at http://ca.com/support or MyCA, follow these steps:
This approach ensures that your issue or request is routed to the proper support team.
Symptom:
In the Usage Report request form, the Usage Reports drop-down does not populate.
Solution:
To enable Automatic Usage Reporting, administrator must modify the Amazon Web Services Account Billing Preferences.
Create an S3 bucket to locate the Usage Reports, and add a usage policy to allow Amazon Web Services to deposit usage reports into the specified S3 bucket. For more details, see the Amazon Web Services documentation.
Symptom:
PAM processor or operator execution fails with an error message like Signature not yet current or Signature expired.
Solution:
Check the time stamp of the server where the CA Process Automation server is installed. The time must be in synchronization with the current time selected in the time zone in the box where CA Process Automation is installed.
Symptom:
PAM process or operator execution fails with the following error message:
The element type "BR" must be terminated by the matching end-tag "</BR>".
Note: The proxy information is requested after a given inactivity interval after a successful login. Hence, running with the correct information causes a delay, after which the incorrect proxy information is ignored. The proxy server does not request authorization again until an inactivity interval has elapsed.
Solution:
Do one of the following:
Proxy Host Name, Proxy Port, Proxy Username, Proxy Password, and Proxy Domain Name.
Symptom:
When a Virtual Business Service is stopped, its associated Elastic IPs are released and returned to the Elastic IP resource pool.
Solution:
Attach another Elastic IP to Virtual Business Service when a Virtual Business is restarted.
Note: Services that stop a Virtual Business Service include (but not limited to):
Symptom:
The approving manager is not able to approve the user request service.
Solution:
To allow the manager to approve end-user requests, each manager user accounts in CA Service Catalog must have an authorization level of 20 or above.
The page opens with a list of users.
You have successfully granted Authorization Level 20 to the manager user account.
Symptom:
Option or service to delete Snapshots, Elastic IP, and Elastic Block Store Volumes which were create using a self-service portal does not exist.
Solution:
This service is not supported. Administrator has to delete the resources manually from the Amazon website.
Symptom:
As an end user I have successfully requested a new AWS instance. How am I notified about the network address of the new Amazon instance and the credentials to access it?
Solution:
Open the request that you submitted and check the Notes grid for instance details.
Symptom:
A message appears prompting script is taking longer to execute while the service is searching for the template.
Solution:
If the data of the search criteria is large, it takes longer than expected time to load form.
Symptom:
I am not able to connect to my provisioned EC2 instance using remote desktop/Secure Shell (SSH).
Solution:
Configure default security groups to enable the end-user access to the EC2 instances using the remote desktop/Secure Shell (SSH).
