The CA Automation Suite for Clouds powered by Amazon Web Services contains a combination of the following items:
Important! Install the solution in the order that is specified in this guide, because installations and configurations are cross-dependent. A deviation from installation and configuration procedures is not supported unless recommended. These procedures also assume that you have the required infrastructure and non-CA Technologies software installed.
