Previous Topic: Set up Administrator Account, Map it to AWS AccountNext Topic: Configure Automated Task
Synchronize the Account
The AWS Amazon Machine Image to Management Database (AMI2MDB) synchronization tool is provided to customers to maintain a current list of AMIs in the local MDB. Install and configure the AWS AMI2MDB synchronization tool to run as a scheduled task.
Note: The account synchronization step is possible after at least one master account is created in the ASC AWS Manage Master Accounts Service in the CA Service Catalog. This tool uses the account information for each master account to download and populate the MDB with both public and private AMIs from Amazon.
  1. Log in to CA Service Catalog.
  2. Locate the AMI2MDB Sync Tool, navigate to the following folder:
    %USM_HOME% \filestore\contentpacks\CA ASC Amazon Web Services\bin\ SyncAMI
    The folder contains the following files:
    Run EncryptPassword.cmd
    Specifies the batch file that is used to encrypt and save the MDB password.
    appresources.properties
    Specifies the properties file that contains the application resource path information.
    RunAWSSync.bat
    Specifies the Windows-executable file that wraps the main executable JAR file.
    sync_props.xml
    Specifies the file that contains credentials for AWS and MDB database connections.
    SyncAMI2.jar
    Specifies the main exported executable JAR file that contains all the business rules for this application.
  3. Update the configuration file (sync_props.xml) with the required AWS and MDB account information:
    Note: Accept the default DB Password.
  4. Execute EncryptPassword.cmd and type the SQL Admin password.
    The encrypted password is in the configuration file sync_props.xml.
  5. Execute RunAWSSync.bat
  6. Execute the java –jar SyncAMIs.jar – a SyncAMI file.
    Once the AWSSync.bat is run, it can take between 15-45 minutes to download the AMIs.
    The picture illustrates the command prompt window indicating the synchronization status.
    The synchronization process starts.
    After the process completes, you can analyze the results by querying the MDB database. Run the following query to get the results of the processed AMI records:
    USE mdb;
    SELECT
    SyncLog.TotalAMIsProcessed as TotalProcessed,
    SyncLog.AMIsInserted as TotalInserted,
    SyncLog.AMIsUpdated as TotalUpdated,
    SyncLog.SecondsElapse / 60 as MinutesElapsed,
    AZ.Name as Region,
    SyncLog.SyncToken as SyncToken,
    CONVERT(VARCHAR, SyncLog.StartDateTime, 109) as StartTimestamp,
    CONVERT(VARCHAR, SyncLog.EndDateTime, 109) as EndTimestamp
    FROM
    dbo.ASC_AWS_AMIs_Sync_Log as SyncLog,
    dbo.ASC_AWS_REGIONS as AZ
    WHERE SyncLog.AvailabilityZoneId = AZ.ASC_AWS_REGION_ID
    AND AZ.isActive = 1
    ORDER BY SyncLog.StartDateTime desc
