Install and Configure CA Automation Suite for Clouds Powered by Amazon Web Services › Synchronize AWS Master Account › Configure Automated Task
Automate the Sync process by adding it to the server Windows Tasks.
- Go to Control Panel\ All Control Panel Items\ Administrative Tools, click Task Scheduler.
A wizard open with fields for configuring task.
- Select Create a Basic Task.
- Type the Name and Description, click Next.
- Select Trigger to set the frequency of task occurrence, we recommend Daily, click Next.
- Select Daily, the start date, the time, and recurrence, click Next.
- Select Action, Start a Program, and click Next.
- Select Start a Program.
- Browse and select the RunAWSSync.bat file, click Next.
- Verify your settings, click Finish.
- Select the Task Scheduler Library folder.
The Automation task is configured.
The AMI templates from Amazon are available in MDB for use in the service cartridge.
