This parameter specifies the internal buffer size for sends and receives. The default size allows multiple CA XCOM Data Transport records to be received in a single socket call. With this default, if your CA XCOM Data Transport record size is less than 32K, CA XCOM Data Transport will attempt to receive multiple records in a single socket call. Used for TCP/IP transfers only.
Specifies the internal buffer size for sends and receives for TCP/IP transfers.
Default: 32768
