Indicates the frequency with which CA XCOM Data Transport checks to see if incoming error information is available when sending data. For example, if the value is 5, a check is made every fifth time that data is sent, to determine if data is available for receiving. Larger values give better performance. Smaller values minimize the sending of data after the partner reports an error. Used for TCP/IP transfers only.
The interval that data sends are checked for incoming error information.
Default: 10
