The job name or started task name of the TCP/IP stack that CA XCOM Data Transport uses. If multiple stacks are running at your site, use this parameter to specify the required stack. The TCP/IP stack that is specified is used for both initiating and receiving transfers.
Specifies up to eight alphanumeric characters indicating the job name or started task name of the TCP/IP stack that CA XCOM Data Transport uses.
Default: None
Notes:
