Previous Topic: TCPSRCVBNext Topic: TCPSTACK
TCPSSNDB
TCP/IP Socket option SO_SNDBUF. This parameter specifies the buffer size for sends. Use 0 for the default size provided by the socket implementation. The value for TCPSSNDB can be smaller than the value for TCPTBUF. Used for TCP/IP transfers only.
0 to 256000
Specifies the buffer size for sends for TCP/IP transfers.
Default: 64
Notes:
