Configuration Parameters › CONFIG Member Parameters › TCPSRCVB
TCPSRCVB
TCP/IP Socket option SO_RCVBUF. This parameter specifies the buffer size for receives. Use 0 for the default size provided by the socket implementation. The value for TCPSRCVB can be smaller than the value for TCPTBUF. Used for TCP/IP transfers only.
- 0 to 256000
Specifies the size of the TCP/IP receive buffer.
Default: 64
Notes:
- A value in the range 1 to 250 is interpreted as K bytes while 251 and above is interpreted as bytes.
- This value is rounded to the next highest 4K.
- The maximum value allowed for this parameter may differ from one z/OS version to another. If errors occur during server startup, then the value of this parameter needs to be lowered.
