Important! The existing XCOMPLEX facility has been deprecated. The following information is provided for backward compatibility only. All new installations can use the new PLEXQ implementation. The existing XCOMPLEX users can migrate to the PLEXQ infrastructure for their XCOMPLEX functionality.
Typically, the XCOMPLEX Admin Server is brought up first, then the XCOMPLEX Worker Servers, although it is not required.
To start an XCOMPLEX Admin Server.
Enter one of the following commands on the z/OS console where the user is authorized to invoke z/OS system commands:
Many of the messages that are displayed when you start the XCOMPLEX Admin Servers are the same as when you start a standalone server but the following are some of the additional messages you can see. Note the XCOMM0045I message, which indicates that an XCOMPLEX Worker Server has successfully connected to the Admin Server.
XCOMM0990I ACTUAL XCOMDFLT PARMS:
XCOMM0991I XCOMPLEX = XCOMPLEX_BAS
XCOMM0008I XBAS31A ACB OPENED SUCCESSFULLY
XCOMM0009I COMPILED UNDER VTAM V6 R1 M9 - EXECUTING UNDER VTAM V6 R1 M9
5695-11701-190
XCOMM0763I DEFAULT TABLE BASAD115 LOADED. GENERATED 02/12/08 AT 23.43
XCOMM0027I ESTAE ROUTINE HAS BEEN ESTABLISHED
XCOMM0056I CA XCOM(TM) r12.0 (GEN LEVEL 1203 SP00) IS UP AND ACCEPTING
LOGONS
XCOMM0056I ON CPU 2097 SERIAL # 0CE000 IN 31-BIT MODE MVS SP7.0.9
XCOMM1000I STARTING CROSS-SYSTEM COUPLING FACILITY SERVICE TASK
XCOMM0066I * TRACE REQUEST COMPLETED SUCCESSFULLY
XCOMM0806I STARTING XCOM TCP/IP SSL LISTENER
XCOMM0821I STARTING XCOM TCP/IPV6 SSL LISTENER
XCOMM1068I CROSS-COUPLING FACILITY LISTENER TASK STARTING
XCOMM0803I STARTING XCOM TCP/IP LISTENER
XCOMM0820I STARTING XCOM TCP/IPV6 LISTENER
XCOMM0566E TYPE=PARAMETER NOT FIRST CARD IN XCOMCNTL MEMBER CICSJSA
XCOMM0559I XCOMRTL ENABLED SUCCESSFULLY
XCOMM0559I XCOMMVS2 ENABLED SUCCESSFULLY
XCOMM0559I XCOMNG0 ENABLED SUCCESSFULLY
XCOMM0807I XCOM TCP/IP SSL LISTENER ACTIVE ON PORT 46656, STACK ***ALL**
XCOMM0819I TCP/IP FUNCTION GETHOSTID RETURNS ADDRESS 141.202.65.31
XCOMM0788I XCOM TCP/IP LISTENER ACTIVE ON PORT 46655, STACK ***ALL**
XCOMM0823I XCOM TCP/IPV6 SSL LISTENER ACTIVE ON PORT 46658, STACK ***ALL**
XCOMM0819I TCP/IP FUNCTION GETHOSTID RETURNS ADDRESS ::ffff:141.202.65.31
XCOMM0822I XCOM TCP/IPV6 LISTENER ACTIVE ON PORT 46657, STACK ***ALL**
XCOMM1019I XCF CONNECT STR=XCOMPLEX_BAS , CONN=XBAS31A , RC=00000000,
RSN=00000000, DISP=NEW
XCOMM1020I MAXIMUM SERVERS SUPPORTED=00000061
XCOMM1054I MAXIMUM LIST ENTRIES SUPPORTED=00001392
XCOMM1021I ALLOCATING MASTER ENTRY IN LIST #0000
XCOMM1028I ADDING SERVER ENTRY FOR NODE (XBAS31A ) WHICH IS USING LIST #0001
XCOMM0454I OPERLIM EXCEEDS XCF MAX ENTRIES. OPERLIM REDUCED TO VALUE IN XCOMM1054I
MESSAGE
XCOMM1005I XCOMPLEX SERVICES ENABLED FOR NODE (XBAS31A )
XCOMM0451I XBAS31W NOW CONNECTED TO XCOMPLEX ADMIN XBAS31A
Note: Specifying an unsupported parameter or an invalid value for a parameter results in the CA XCOM Data Transport admin server terminating. This applies to an EXEC PARM or a Configuration member parameter. A message indicating which parameter caused termination is displayed in the XCOMINIT log.
