When you have activated the XCOMXFER server and specified the START parameter, you can start CA XCOM Data Transport.
To start CA XCOM Data Transport
Enter one of the following commands on the z/OS console (or any TSO/ISPF or NETVIEW session) where the user is authorized to invoke z/OS system commands:
Several informational messages are displayed when CA XCOM Data Transport is started, as shown in the following example:
XCOMM0890I zIIP PROCESSING HAS BEEN ENABLED XCOMM0008I XBAS31W ACB OPENED SUCCESSFULLY XCOMM0009I COMPILED UNDER VTAM V6 R1 MD - EXECUTING UNDER VTAM V6 R1 MD 5695-11701-1D0 XCOMM0891I 006 OF 008 STANDARD CPUs ARE ONLINE IN LPAR XCOMM0891I 003 OF 004 zIIP CPUs ARE ONLINE IN LPAR XCOMM0896I zIIP PROCESSING FOR COMPRESSION IS ENABLED XCOMM0479I TRANSFER QUEUE IS BEING WARM STARTED XCOMM0037I PSO SUBTASK ATTACHED SUCCESSFULLY XCOMM0330I PRIMARY SUBSYSTEM IS JES2 XCOMM0056I CA XCOM(tm) v12.0 (GEN LEVEL 1307 SP00) IS UP AND ACCEPTING LOGONS XCOMM0056I ON CPU 2827 SERIAL # 0C4D07 IN 31-BIT MODE MVS SP7.1.3 XCOMM1000I STARTING CROSS-SYSTEM COUPLING FACILITY SERVICE TASK XCOMM0027I XCOMSTIM ESTAE ROUTINE HAS BEEN ESTABLISHED XCOMM0027I XCOMTASK ESTAE ROUTINE HAS BEEN ESTABLISHED XCOMM0027I XCOMRANX ESTAE ROUTINE HAS BEEN ESTABLISHED XCOMM1068I CROSS-COUPLING FACILITY LISTENER TASK STARTING XCOMM0027I XCOMRANT ESTAE ROUTINE HAS BEEN ESTABLISHED XCOMM0803I STARTING XCOM TCP/IP LISTENER XCOMM0027I XCOMRANQ ESTAE ROUTINE HAS BEEN ESTABLISHED XCOMM1168I PLEXQ LISTENER TASK STARTING XCOMM0027I XCOMRANY ESTAE ROUTINE HAS BEEN ESTABLISHED XCOMM0027I MAINTASK ESTAE ROUTINE HAS BEEN ESTABLISHED XCOMM1101I CONNECTED TO PLEXQ GROUP PLEXQ1 AS XBAS31W XCOMM0788I XCOM TCP/IP LISTENER ACTIVE ON PORT 06653, STACK ***ALL** XCOMM0819I TCP/IP FUNCTION GETHOSTID RETURNS ADDRESS
As it initializes, CA XCOM Data Transport issues one XCOMM0559I message for each member that is enabled, as shown:
XCOMM0559I AS400 ENABLED SUCCESSFULLY XCOMM0559I MVSPAR ENABLED SUCCESSFULLY
Note: Specifying an unsupported parameter or an invalid value for a parameter results in the CA XCOM Data Transport server terminating. This applies to an EXEC PARM or a Configuration member parameter. A message indicating which parameter caused termination is displayed in the XCOMINIT log.
