Previous Topic: Start the XCOMPLEX Admin Server (Deprecated)Next Topic: Perform a Direct File Transfer (TYPE=EXECUTE)
Start the XCOMPLEX Worker Server (Deprecated)
Important! The existing XCOMPLEX facility has been deprecated. The following information is provided for backward compatibility only. All new installations can use the new PLEXQ implementation. The existing XCOMPLEX users can migrate to the PLEXQ infrastructure for their XCOMPLEX functionality.
Normally the XCOMPLEX Admin Server is brought up first, then the XCOMPLEX Worker Servers, although it is not a requirement.
To start an XCOMPLEX Worker Server.
Enter one of the following commands on the z/OS console where the user is authorized to invoke z/OS system commands:
Several informational messages are displayed when CA XCOM Data Transport is started, as shown in the following excerpt:
XCOMM0991I XCOMPLEX         = XCOMPLEX_BAS
XCOMM0008I XBAS31W  ACB OPENED SUCCESSFULLY
XCOMM0009I COMPILED UNDER VTAM V6 R1 M9 - EXECUTING UNDER VTAM V6 R1 M9
           5695-11701-190
XCOMM0763I DEFAULT TABLE BASWK115 LOADED. GENERATED 03/17/08 AT 21.51
XCOMM0027I ESTAE ROUTINE HAS BEEN ESTABLISHED
XCOMM0037I PSO SUBTASK ATTACHED SUCCESSFULLY
XCOMM0330I PRIMARY SUBSYSTEM IS JES2
XCOMM1000I STARTING CROSS-SYSTEM COUPLING FACILITY SERVICE TASK
XCOMM0056I               CA XCOM(TM) r12.0 (GEN LEVEL 1203 SP00) IS UP AND
           ACCEPTING LOGONS
XCOMM0056I ON CPU 2097 SERIAL # 0CE000 IN 31-BIT MODE MVS SP7.0.9
XCOMM1068I CROSS-COUPLING FACILITY LISTENER TASK STARTING
XCOMM0803I STARTING XCOM TCP/IP LISTENER
XCOMM0788I XCOM TCP/IP LISTENER ACTIVE ON PORT 06653, STACK ***ALL**
XCOMM0819I TCP/IP FUNCTION GETHOSTID RETURNS ADDRESS 141.202.65.31
XCOMM0559I XBAS31A  ENABLED  SUCCESSFULLY
XCOMM0559I XCOMMVS2 ENABLED  SUCCESSFULLY
XCOMM0559I BASLIST  ENABLED  SUCCESSFULLY
XCOMM1019I XCF CONNECT STR=XCOMPLEX_BAS    , CONN=XBAS31W , RC=00000000,
           RSN=00000000, DISP=OLD
XCOMM1020I MAXIMUM SERVERS SUPPORTED=00000061
XCOMM1054I MAXIMUM LIST ENTRIES SUPPORTED=00001392
XCOMM1017I XCF READING MASTER ENTRY FROM LIST #0000
XCOMM1013I XCF REQ=READ             RC=00000000 REASON=00000000 LIST=0000
           ENTRY=XCOMPLEX_BAS
XCOMM1022I LOCATING SERVER ENTRY IN LIST #0000
XCOMM1026I UPDATING MASTER ENTRY IN LIST #0000
XCOMM1028I ADDING SERVER ENTRY FOR NODE (XBAS31W ) WHICH IS USING LIST #0002
XCOMM0454I OPERLIM EXCEEDS XCF MAX ENTRIES. OPERLIM REDUCED TO VALUE IN
           XCOMM1054I MESSAGE
XCOMM1005I XCOMPLEX SERVICES ENABLED FOR NODE (XBAS31W )
Note: Specifying an unsupported parameter or an invalid value for a parameter results in the CA XCOM Data Transport worker server terminating. This applies to an EXEC PARM or a Configuration member parameter.
