Previous Topic: Display ACBsNext Topic: Start Your Product
Specify the START Parameter
The START parameter can be specified through the EXEC PARM options of the CA XCOM Data Transport server JCL. In the following sample EXEC statement, the START parameter is set to the value STARTUP. STARTUP is a member of the XCOMCNTL data set that is initialized at system startup.
//SERVER  EXEC  PGM=XCOMXFER,                          X
//              TIME=1440,                             X
//              REGION=128M,                           X
//              PARM='ACBNAME=XCOMAPPL,START=STARTUP'
Note: If no destinations are to be enabled during initialization of the CA XCOM Data Transport server, the member STARTUP can contain a comment statement only. If the member STARTUP is not found in the XCOMCNTL data set, you will see the message XCOMM0265E for the member, and no TYPE=SCHEDULE transfers will be activated.
