Previous Topic: Activate the Application Major NodeNext Topic: Specify the START Parameter
Display ACBs
After activating the application major node, you can display the ACBs by issuing the following command:
D NET,ID=APPLXCOM,E
In response, VTAM displays the ACBs in the application major node, as shown in the following table. Note that the status of the ACBs should be CONCT.
IST097I DISPLAY ACCEPTED
IST075I NAME = APPLXCOM, TYPE = APPL SEGMENT 027
IST486I STATUS= ACTIV, DESIRED STATE= ACTIV
IST360I APPLICATIONS:
IST080I XCOMAPPL CONCT   XCOMM00  CONCT   XCOMM01  CONCT
IST080I XCOMM02  CONCT   XCOMM03  CONCT   XCOMM04  CONCT
IST080I XCOMM05  CONCT
IST314I END
