Configuration Parameters › CONFIG Member Parameters › PSOCKPT
PSOCKPT
Specifies the interval for checkpoints taken during a PSO transfer.
- 0 to 9999 records
Specifies the number of PSO records to transfer before a checkpoint is taken.
Default: 1000
Notes:
- The checkpoint/restart facility resumes interrupted PSO transfers from the point at which the most recent checkpoint was taken.
- The smaller the checkpoint interval, the greater the effect on the throughput, due to frequent checkpointing. Setting this parameter less than 10 would severely degrade performance. Usually values from 100 to 1000 are sufficient. Set this parameter to 0 if you do not want to do checkpointing.
