Configuration Parameters › CONFIG Member Parameters › PSODISP
PSODISP
This parameter does both of the following:
- Specifies the disposition of a PSO data set if CA XCOM Data Transport is unable to successfully complete a PSO transfer.
- Sets the DISP flag in a PSO transfer. DISP determines whether to keep or delete the report file after printing on the remote system. This value is ignored when the remote system is an IBM mainframe.
- DELETE
- Deletes the PSO data set after an unsuccessful PSO transfer.
- Deletes the report file after it is printed on the remote system.
- KEEP
- Keeps the PSO data set after an unsuccessful PSO transfer.
- Keeps the report file after it is printed on the remote system (by removing the temporary files).
Defaults: KEEP
Notes:
- If PSODISP=DELETE, manual intervention is required to requeue the transfer to CA XCOM Data Transport.
- If PSODISP=KEEP, manual intervention may be required to reclaim space on the remote system.
