Specifies whether CA XCOM Data Transport will start a PSO subtask to transfer JES spool files.
CA XCOM Data Transport will automatically start a PSO subtask to transfer JES spool files. The PSO subtask will query the JES spool at regular intervals to see if there are any spool files that need to be transferred.
Prevents the starting of the PSO subtask. JES spool will not be queried for spool files. However, any overhead associated with the checking for spool files will also be eliminated.
Default: YES
Important! The PSO default parameter can be specified on the XCOMXFER EXEC parameter only. It cannot be specified in the default table or CONFIG member.
Note: With PSO=YES, use the JESINTV parameter to specify the interval in seconds at which the JES spool is scanned.
