Previous Topic: PLEXQNext Topic: PSO
PRI
This parameter specifies the default amount of primary space that is allocated to new data sets in the units that the ALLOC parameter specifies.
1 to 16,277,215
Specifies the amount of primary space that is allocated to new data sets. The ALLOC parameter determines the unit of allocation.
Default: 10 (blocks, cylinders, tracks, or records depending on the value of the ALLOC parameter)
Note: Related parameters are ALLOC, AVGREC, SEC, DIR, CATALOG, UNIT, VOL, PSOUNIT, and PSOVOL.
