Previous Topic: EXIT02Next Topic: EXIT04
EXIT03
Specifies whether CA XCOM Data Transport User Exit 3 should be enabled. EXIT03 allows the extraction of information from a JES3 address space that is not available via the subsystem interface.
YES
Specifies that the exit is enabled and will use load module XCOMEX03.
NO
Specifies that the exit is not enabled.
Load Module name
Specifies that the named module is to be loaded and called as User Exit 3.
Default: No.
