Specifies whether CA XCOM Data Transport User Exit 4 should be enabled. Exit 4 is used to supplement several layers of operator security facilities provided by CA XCOM Data Transport.
Specifies that the exit is enabled and will use load module XCOMEX04.
Specifies that the exit is not enabled.
Specifies that the named module is to be loaded and called as User Exit 4.
Default: No.
Note: A sample version of this exit is provided in CAI.CBXGSAMP(XCOMEX04). For more information about this user exit, see the appendix User Exits in the CA XCOM Data Transport for z/OS User Guide.
