Previous Topic: EXIT01Next Topic: EXIT03
EXIT02
Specifies whether CA XCOM Data Transport User Exit 2 should be enabled. Exit 2 allows the extraction of information from a JES2 address space that is not available via the subsystem interface.
YES
Specifies that the exit is enabled, and will use load module XCOMEX02.
NO
Specifies that the exit is not enabled.
Load Module name
Specifies that the named module is to be loaded and called as User Exit 2.
Default: No.
