Previous Topic: EXECUTENext Topic: EXIT02
EXIT01
Specifies whether CA XCOM Data Transport User Exit 1 should be enabled. Exit 1 is invoked at the end of a successfully completed file transfer.
YES
Specifies that the exit is enabled, and will use load module XCOMEX01.
NO
Specifies that the exit is not enabled.
Load Module name
Specifies that the named module is to be loaded and called as User Exit 1.
Default: No.
Note: A sample version of this exit is provided in CAI.CBXGSAMP (XCOMEX01). For more information about this user exit, see the appendix User Exits in the CA XCOM Data Transport for z/OS User Guide.
