Previous Topic: VTAPE_MODULE_CONSISTENCYNext Topic: VTAPE_INACTIVE_RECALLSERVER
VTAPE_DATAQ_ALLOCATION
Description
The Data Queue (VDATAQ) environment failed to initialize the VDATAQ data set. VDATAQ data set is a temporary repository for storing messages that cannot be immediately transmitted to a remote CA Vtape subsystem. If the remote is available the message data is transmitted to the remote’s VDATAQ and any necessary action is taken. One example of the message traffic is the transmittal of scratch requests for Virtual Volumes that were sent by Peer-To-Peer to the remote subsystem.
Because the VDATAQ data set was not created, any messages still queued for remote transmission will be lost when CA Vtape is terminated.
Best Practice
Review the z/OS System Log for error messages pertaining to the allocation request. The typical problem is a security or SMS change. Correct the error and restart CA Vtape.
If the error cannot be found, search the CA problem reporting databases for a resolution. If you are unable to find a resolution to the error, contact CA Technical Support for assistance.
Parameters Accepted
None
Debug Support
Yes
Verbose Support
Yes
Reference
For more information about P2P, see the chapter "CA Vtape P2P Option".
Messages
SVTH1401E
CA Vtape Peer-To-Peer VDATAQ items will not be saved across subsystem restarts.
