Previous Topic: VTAPE_CDS_SEPARATIONNext Topic: VTAPE_DATAQ_ALLOCATION
VTAPE_MODULE_CONSISTENCY
Description
The main address space and the sub address spaces are running with the same load modules, but at different maintenance levels. This can occur when:
Maintenance has been applied to the loadlib and a single address space has been restarted instead of the entire CA Vtape subsystem.
Best Practice
Ensure that all CA Vtape address spaces are started with the same maintenance level library. Changing the CA Vtape Split Maintenance-Level Protection to run in AUTOMATIC mode is recommended. Split Maintenance-Level Protection is controlled by the TaskLib attribute in the Startup Options Section of parmlib.
Parameters Accepted
None
Debug Support
Yes
Verbose Support
Yes
Reference
For more information, see Split Maintenance-Level Protection in this guide and STARTUP OPTIONS in the Configuration Guide.
Messages
SVTH1301E
The CA Vtape address spaces are not all running with the same maintenance level.
