Report SVTRC125.C lists the Virtual Volume Files selected for input. Only volumes for the group and subgroup or subgroups specified by the RECYCLE command are listed. If multiple RECYCLE commands are coded, a report will be produced for each command.
Example of the SVTRC125.C report
RECYCLE.SVTRC125.C CA11.SVT2 CA VTAPE HH:MM:SS mm/dd/yy PAGE# 9 CA VTAPE R11.5 SELECTED VIRTUAL VOLUME FILES GROUP# 61 VIRTUAL DSN PHYSICAL FILE ESTIMATED GROUP SUB VOLSER SEQ VOLSER SEQ# #MB.USED PHYSICAL FILENAME REF# ----- --- ------ --- ------ ------ -------- -------------------------------------------- -------- 61 S 101744 P 540336 1 8 QAPROD.VVE.V101744.PRIMARY 1 61 S 101745 P 540336 2 8 QAPROD.VVE.V101745.PRIMARY 2 61 S 101746 P 540336 3 8 QAPROD.VVE.V101746.PRIMARY 3 61 S 101747 P 540476 1 8 QAPROD.VVE.V101747.PRIMARY 4 61 S 101748 P 540476 2 8 QAPROD.VVE.V101748.PRIMARY 5 61 S 101750 P 540476 3 8 QAPROD.VVE.V101750.PRIMARY 6 61 S 101751 P 540520 1 8 QAPROD.VVE.V101751.PRIMARY 7 61 S 101752 P 540520 2 8 QAPROD.VVE.V101752.PRIMARY 8 61 S 101753 P 540520 3 8 QAPROD.VVE.V101753.PRIMARY 9 61 S 101754 P 540562 1 8 QAPROD.VVE.V101754.PRIMARY 10 61 S 101756 P 540562 2 8 QAPROD.VVE.V101756.PRIMARY 11 61 S 101758 P 540562 3 8 QAPROD.VVE.V101758.PRIMARY 12 61 S 101759 P 540692 1 8 QAPROD.VVE.V101759.PRIMARY 13 61 S 101760 P 540692 2 8 QAPROD.VVE.V101760.PRIMARY 14 61 S 101761 P 540692 3 8 QAPROD.VVE.V101761.PRIMARY 15 61 S 101602 P 541202 1 8 QAPROD.VVE.V101602.PRIMARY 16 61 S 101603 P 541202 2 8 QAPROD.VVE.V101603.PRIMARY 17 61 S 101739 P 541202 3 8 QAPROD.VVE.V101739.PRIMARY 18 61 S 101740 P 541202 4 8 QAPROD.VVE.V101740.PRIMARY 19 61 S 101741 P 541202 5 8 QAPROD.VVE.V101741.PRIMARY 20 61 S 101565 P 541284 1 8 QAPROD.VVE.V101565.PRIMARY 21 61 S 101566 P 541284 2 8 QAPROD.VVE.V101566.PRIMARY 22 61 S 101568 P 541284 3 8 QAPROD.VVE.V101568.PRIMARY 23 61 S 101572 P 541284 4 8 QAPROD.VVE.V101572.PRIMARY 24 61 S 101574 P 541284 5 8 QAPROD.VVE.V101574.PRIMARY 25 61 S 101577 P 541284 6 8 QAPROD.VVE.V101577.PRIMARY 26 61 S 101579 P 541284 7 8 QAPROD.VVE.V101579.PRIMARY 27 61 S 101581 P 541284 8 8 QAPROD.VVE.V101581.PRIMARY 28 61 S 101583 P 541284 9 8 QAPROD.VVE.V101583.PRIMARY 29 61 S 101585 P 541284 10 8 QAPROD.VVE.V101585.PRIMARY 30 61 S 101587 P 541284 11 8 QAPROD.VVE.V101587.PRIMARY 31 61 S 101589 P 541284 12 8 QAPROD.VVE.V101589.PRIMARY 32 61 S 101591 P 541284 13 8 QAPROD.VVE.V101591.PRIMARY 33 61 S 101593 P 541284 14 8 QAPROD.VVE.V101593.PRIMARY 34 61 S 101595 P 541284 15 8 QAPROD.VVE.V101595.PRIMARY 35 61 S 101597 P 541284 16 8 QAPROD.VVE.V101597.PRIMARY 36 61 S 101599 P 541284 17 8 QAPROD.VVE.V101599.PRIMARY 37 61 S 101601 P 541284 18 8 QAPROD.VVE.V101601.PRIMARY 38
