Report SVTRC125.4 summarizes the projected results of the RECYCLE process. The left side of the report shows the input statistics and the right side shows the estimated results of performing a LIVE recycle run. Only statistics for the group specified by the RECYCLE command are listed. If multiple RECYCLE commands are coded, a report will be produced for each command.
The #Physical Volumes* report column defines the number of mounts required to complete the Recycle request. A physical volume may be mounted up to three times; one mount for each subgroup. Therefore, the #Physical Volumes* column does not actually reflect the number of physical volumes that are processed. Refer to the Volume Pull List Report (SVTRC190.A) to get the actual number of physical volumes that are to be mounted to process the Recycle request.
As Virtual Volumes age and the number of remaining retention days decrease, Recycle will change the Virtual Volumes subgroup assignment. The associated physical volumes will now contain Virtual Volumes for more than one subgroup. If Recycle is processing multiple subgroups for a group, these physical volumes will be mounted multiple times, once for each subgroup processed. The pull list VOLSER order reflects the first time a physical volume is mounted.
Example of the SVTRC125.4 report
RECYCLE.SVTRC125.4 CA11.SVT2 CA VTAPE HH:MM:SS mm/dd/yy PAGE# 10 CA VTAPE R11.5 PROJECTED OUTPUT FOR SELECTED VIRTUAL VOLUME FILES GROUP# 61 UTILIZATION STATISTICS SUMMARIZED BY DEVICE TYPE & SUBGROUP - - - - - - - - I N P U T - - - - - - - - - - - - P R O J E C T E D O U T P U T - - - DEVICE SHORT MEDIUM LONG TOTAL DESCRIPTION SHORT MEDIUM LONG TOTAL ------ ---------- ---------- ---------- ---------- ------------------------ ---------- ---------- ---------- ---------- 3590 0.3 0.0 0.0 0.3 #GB USED 0.3 0.0 0.0 0.3 7 0 0 7 #PHYSICAL VOLUMES* 1 0 0 1 0.1 0.0 0.0 0.1 AVG#(%USED/VOLUME*) 0.7 0.0 0.0 0.7 43.4 0.0 0.0 43.4 AVG#(#MB.USED/VOLUME*) 304.0 0.0 0.0 304.0 38 0 0 38 #PHYSICAL FILES 38 0 0 38 5.4 0.0 0.0 5.4 AVG#(FILES/VOLUME*) 38.0 0.0 0.0 38.0 8.0 0.0 0.0 8.0 AVG#(#MB.USED/FILE) 8.0 0.0 0.0 8.0 TOTALS 0.3 0.0 0.0 0.3 #GB USED 0.3 0.0 0.0 .3 7 0 0 7 #PHYSICAL VOLUMES* 1 0 0 1 43.4 0.0 0.0 43.4 AVG#(#MB.USED/VOLUME*) 304.0 0.0 0.0 04.0 38 0 0 38 #PHYSICAL FILES 38 0 0 38 5.4 0.0 0.0 5.4 AVG#(FILES/VOLUME*) 38.0 0.0 0.0 38.0 8.0 0.0 0.0 8.0 AVG#(#MB.USED/FILE) 8.0 0.0 0.0 8.0 NOTE: * PHYSICAL VOLUMES PER SUBGROUP
