Previous Topic: Candidate Physical Backstore Volumes (Sorted by subgroup)Next Topic: Selected Virtual Volume Files
Summarized By Device Type and Subgroups
Report SVTRC125.3 summarizes the candidate physical volumes utilization statistics by device type and subgroup for the group specified by the RECYCLE command. If multiple RECYCLE commands are coded, a report will be produced for each command.
Example of the SVTRC125.3 report
RECYCLE.SVTRC125.3  CA11.SVT2                          CA VTAPE                    19:25:48 12/07/06  PAGE#     8 CA VTAPE R11.5                            CANDIDATE PHYSICAL BACKSTORE VOLUMES GROUP# 61                     UTILIZATION STATISTICS SUMMARIZED BY DEVICE TYPE & SUBGROUP        - - - - - - - - I N P U T - - - - - - - - - DEVICE      SHORT     MEDIUM       LONG      TOTAL        DESCRIPTION ------ ---------- ---------- ---------- ---------- -------------------------- 3590          0.3        0.0        0.0        0.3         #GB USED                 7          0          0          7    #PHYSICAL VOLUMES*               0.1        0.0        0.0        0.1    AVG#(%USED/VOLUME*)              43.4        0.0        0.0       43.4  AVG#(#MB.USED/VOLUME*)                38          0          0         38      #PHYSICAL FILES               5.4        0.0        0.0        5.4    AVG#(FILES/VOLUME*)               8.0        0.0        0.0        8.0    AVG#(#MB.USED/FILE)   TOTALS        0.3        0.0        0.0        0.3         #GB USED                 7          0          0          7    #PHYSICAL VOLUMES*              43.4        0.0        0.0       43.4  AVG#(#MB.USED/VOLUME*)                38          0          0         38      #PHYSICAL FILES               5.4        0.0        0.0        5.4    AVG#(FILES/VOLUME*)               8.0        0.0        0.0        8.0    AVG#(#MB.USED/FILE)                                            NOTE: * PHYSICAL VOLUMES PER SUBGROUP
