This command activates or deactivates the high-speed open option used by CA Vtape for Externalizing or Recalling Virtual Volumes to or from Backstore Tapes. You must issue the command on each LPAR where the option needs to be changed.
SVTn SET HSOPEN={ON | OFF}
You can determine the current setting for this option by issuing the SVTn DISPLAY STATUS console command. The default setting is ON.
