Previous Topic: SET CONSOLE=Next Topic: SET HSOPEN=
SET CPU=
This command allows the CPU mode to be changed. You must issue the command on each LPAR where the mode needs to be changed.
Syntax
SVTn SET CPU={ISOLATION | STANDARD}
You can determine the current setting for this option by issuing the SVTn DISPLAY STATUS console command.
For a description of the CPU mode, see the section CPU Performance Compared to Memory Utilization in the Configuration Guide.
Note:  This command is only used for Subsystems running with CacheManagement=Static.
