This command activates and deactivates IDRC support for Backstore Tapes. DEFAULT is the system default as specified in SYSx.IPLPARM or SYS1.PARMLIB member DEVSUPxx. ON is like coding TRTCH=COMP in JCL and OFF is like coding TRTCH=NOCOMP in JCL. You must issue the command on each LPAR where the option needs to be changed.
Note: This option only affects Externalization to or Recycle of Backstore Tapes and has no effect on the application Virtual Volume being written to in the DASD buffer.
SVTn SET IDRC={ON | OFF | DEFAULT}
You can determine the current setting for this option by issuing the SVTn DISPLAY STATUS console command.
