This command allows you to echo unsolicited console output produced by a CA Vtape Subsystem on the console of a system associated with a remote P2P CA Vtape Subsystem. The remote CA Vtape Subsystem must be defined in the parmlib in a Peer To Peer Remotes Section. The console suffix value used by this command will be defined in the appropriate Peer To Peer Remotes Section.
Note: The CA Vtape P2P Option must be licensed to define and activate a remote connection.
SVTn SET Console=(LOCAL | ConsoleSuffix)
Examples of the SET CONSOLE= command
SVT4 SET CONSOLE=S561 SVT4TP000I Console routed to S561, XE61.SVT5 SVT4TP100I Command complete SVT4 SET CONSOLE=LOCAL SVT4TP000I Console reset to LOCAL SVT4TP100I Command complete
Note: The current console status is displayed by the SVTn Display Status console command.
