By default Recall looks to read the Primary source file first when restoring a Virtual Volume. If the Primary source file is not located then Recall looks for a Duplex and then ultimately a Triplex copy. This command changes the order of precedence used by Recall to locate the source file used to restore a Virtual Volume.
You must issue the command for each CA Vtape subsystem where the order needs to be changed.
SVTn SET RECALL={Primary|Duplex|Triplex}
You can determine the current setting for this option by issuing the SVTn DISPLAY STATUS console command.
To change the recall source of individual Virtual Volumes, see the SET RECALL VVE= console command.
