This command changes the maximum number of concurrent UNIX files that the Backstore Engine can use to read or write Triplex USS files. You must issue the command on each LPAR where the limit is to be changed. To immediately lower the number of USS files in use, you may need to stop one or more Externalization tasks.
Note: For more information, see the commands STOP GROUP and STOP PTASKID.
SVTn SET MAXUSS=nn
Where nn is a value between 0 and 99 indicating the maximum number of concurrent UNIX files it can activate.
You can determine the current setting for this option by issuing the SVTn DISPLAY GROUPS console command.
