Previous Topic: SET RECALL=Next Topic: SET THRESHOLD
SET RECALL VVE=
This command sets the Recall order of precedence for locating the source file when restoring a specific Virtual Volume. This causes the identified Recall source to be considered first whenever the Virtual Volume is recalled. This command is used when the default Recall source has become damaged or otherwise unusable.
Syntax
SVTn SET RECALL VVE=volser,{PRImary|DUPlex|TRIplex|P2P|Reset}
Where:
volser
Is the Virtual Volume VOLSER.
Is the desired Recall source override.
Reset
Causes the Recall source override to be reset to the site defined source specified by the SET RECALL= console command.
You can determine the current setting of this option for the specified Virtual Volume using the Virtual Volumes Display of the CA Vtape ISPF Interface.
Note: A recall source override of P2P cannot be processed by a manual recall (SVTn START RECALL=volser).
To change the Recall Source for all Virtual Volumes, see the SET RECALL= console command.
